Brake Question - Silverado 1500
fishpick
Here's the story - this forum was very helpful in describing the issues with the rear Silverado brakes and their tendency to wear out fast! Also other good technical stuff here... So - I got new rotors and pads from a local auto store - fought like hell to get the rear rotors off (large mallet - d**n emergency brake design) and have the whole thing done up new and happy - so I thought.
Now with the new rotors and pads - when rolling along there is a scraping / grinding sound (lower frequency than a squeal) that is made as a function of the rotation of the wheel... When the brake petal is depressed the sound is neither better or worse - just gets slower as the rotation slows...
Here is my hunch - the stupid pads for the emergency brake are now somehow rubbing on the inside of the rotors after pounding the piss out of the old ones to get them off... so, my hunch is I need to take off the calipers and rotors - again - and fiddle around with the shoes that make up the e-brake... Also - since putting new rotors on - the emergency brake pedal in the cab goes all the way to the floor - where as before it only went about half way.
Questions : Does this sound like it makes sense? Do the e-brake shoes adjust like any other drum/shoe system (I recall seeing the star adjuster when the rotor was off)? Is there anything else I should be looking at? How do you adjust the emergency brake cable to make the pedal travel less?
Thanks in advance.
Thanks in advance.
<{POST_SNAPBACK}>
It is supposed to go all the way to the floor. It is self adjusting. Not sure why before it only went half way.
  • 5 years later...
