Help From You Bay Area Guys
methodtical15
hey there bay area folks,
since our weather here in the bay area has finally cleared up, i'm looking into buying some new rims and tires. i live in vallejo and was wondering if you guys have some good rim and tire shops in your city that might give me a good deal.
i've looked locally in my town and have yet to find a decent shop that can give me some good prices. if you guys know of any good shops in your city or anywhere, please hook me up the name of the shop so i can give them a ring and maybe check them out if they can give me a good deal.
i'm looking to get a set of 22's maybe the Eagle 026's or Intro V-Rod 6's with tires. dunno yet? :happysad: i appreciate all your help guys and hope you guys enjoy the nice weather we have here finally!
p.s.- i'm looking to do a McGaughys drop, if you know any good suspension shops that do a good job also, i would like to know to! thanks again
-ejay
  • 5 weeks later...
Might be a drive for you being that you're from Vallejo. They've always done good work for me. As far as Rims and Tires I'd check with them also, they may have a recommendation for you. :cheers:
Bay Truck Accessories
(415) 468-3000
3275 Geneva Ave
Daly City, CA 94014
-Drew
  • 9 months later...
Definately a drive for you, but you can give them a call. They would work with you on the price. They always have for me.
Agundis
South San Francisco
1-650-244-9607
Ask for Patrick (owner)
Anthony
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 480 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
