My experiences and opinon on intakes!
As you have read in here from time to time, I've played around with various intakes on my truck. I've had in order, a home air-aid style intake that I made a box for and used a K&N filter for a 5.7L Vortec engine. It worked better than the UN-modified OEM air box. I then bought a K&N FIPK, it looked better than my home made intake but really didn't perform any better. Then I decided to make a ram-air set up for my OEM air box, it worked better than the FIPK I was using so I kept it and sold the FIPK. I then bought the UPD intake lid and tube for my truck, it seemed to work better but I really didn't test it. I just sold it soly for the intake noise it made under load, similar to the FIPK, that's why I got rid of it also, and that the ram-air worked better. I really expected to lose some performance putting the stock intake tube and air box lid on. Well, after a week with it on, my truck is actually running stronger, my 0-60 times are lower. The only thing I've done to the OEM intake is the ram-air set up and I've blocked off the lower resonation chamber in the intake tube, that's it. The OEM intake is thicker and heavy plastic than either the FIPK or the UPD. That's why it does a better job of controlling intake noise, I believe that's why it also performs better. Being thicker plastic, I believe it's more difficult for engine heat to affect it. The air box with the ram-air stays real cool, I've checked it after I've driven around. On a cool night, it's very cool to the touch. On warmer days, it does heat up but it's not nearly as hot as the surrounding area or the engine. I believe the only restriction in the OEM intake is the air box, you open it up and it'll work nicely. I've done a lot of experimenting on my truck and gone through several intakes and even more mufflers to find what works on my truck. What I've got now, works, period. I just got an AFE filter to test but it's my last hi-flow filter I'm getting. If it works, great, if not, oh well. The Purolator paper filter I'm using works pretty darn good. After reading the air filter test in Hot Rod magazine, the hi-flow filters only produced about 3-4 more hp and tq than the Purolator filter they tested also. They may help squeeze off another .1 seconds off your ET at the track, but that's about it. Well, I'm done and all of this is just my humble opinion and my experiences.
Jim
pics to the ram-air
http://community.webshots.com/album/30727243ATDYPtGZpG
Welcome to the board, great post,
I tend to agree - I am presently waiting for a Volant to use with my Whipple, need the 20% that the Holley filter will give, and I am going to follow your approach for extra air from the front.
Guest Friz
That's quite a bit of testing done at you own expense. Thanks.
That ram air setup looks pretty slick, maybe you could post a step-by-step howto on how you modified the OEM intake? That would be awesome...  :thumbs:
    • Get the 5.3. I`m not a Ford guy.😉   I think these L84`s are less problematic than the L83`s. Certainly less than the L87.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
