Interesting observation....
I pondered this one night after a few :cheers: , What do yall think?
Urban vs. Rural
Urban: When somebody dies (well.... gets murdered) they throw a cover over the body and an outline (of chalk) is left when they remove the body.
Rural: When a car Dies, they throw a tarp over it and an outline (of dead grass) is left when it is removed.
I apologize for the evilness :D , I thought it was funny myself though.
What about.....
Both also leaving some sort of liquid residue/stain after they're removed.
Also, parts and pieces are often removed/resold from both.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
