Pulley swap
I am kicking around the idea of changing out my pulleys to free up some extra power. Any recommendations or things I should be concerned about? I have also been told about light weight pulleys vs. smaller ones. Thanks :cheers:
What pulleys are you planning to swap? Also if you are looking for a magic HP increase, look elsewhere as it only helps a little bit and only at high RPMs too.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
