03+ LED Tail Lights?
Looking for some LED Tail Lights for my 04 chevy (see below) :cheers: . I believe the rear tail light mount and such for 03+ are a tad different then the 99-02 models.
Please any suggestions or links to some nice ones are appreciated.
thanks,
Jason
How about replacing the regular bulbs you probably have in there now with some LED bulbs? Or do you want to replace the whole fixture?
I would like to get some like these: LED SILVERADO TAIL LIGHTS but some places say they fit only up to 2002, and others list 99-05. But I believe the fixture for the tail light of 03 and up are different a bit. Thanks for the suggestion.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
