Anyone know how tough th ezxles are on a 1500?
i got hit directly on the rear wheel pretty hard by a moron in a nissan stanza today. The truck is driving fine but im concerned about the axle and springs in the back. The wheel took a direct hit and he hit me pretty hard, the nissan didnt fare too well( went away on a wrecker lol). Anyone have any thoughts on this? Im going to get it looked at by the dealer. While its driving fine now, i dont want problems to surface down the road.
Unless it bent the wheel I would not be concerned about axle or springs and you would likely damage axle before spring in this wreck because the axle was seated on ground and a lot of the force of impact went to tires not chassis.
I would be more concerned with the inboard axle bearing than the axle itself. A hard hit on the end of the axle could damage the bearings in the carrier assembly. Talk to the dealer and see if they think a check of the bearing lash is in order.
My roomate drives a little mazda pickup and he got hit pretty hard in the drivers side rear wheel by a drunk...dumba$$...anyway, popped the tire, then the car went on to hit the bed. The beds all jacked up but the axle was just fine. Those things are pretty tough. Yours should be fine, but doesn't hurt to check now and save trouble later.
Not unless it bent or broke the wheel. It would take more than that hit to damage carrier bearings. The 10 bolt has some issues but it is not carrier bearing weakness.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
