Rear Door Panel Removal
I have a 2001 Chevy Silverado, and I want to swap my stock 4x6s for a set of Alpines I have, but I can't figure out how to get the d**n rear door panels off with out breaking anything...anyone got any tips?
oh yeah that would be nice to know wouldn't it? I'm a moron sometimes...its a 4 door extended cap, not crew cab
Did you get it?
You have to remove the screw that holds the arm rest on it. the rest of the panel pops off. On the Driver side you have to remove the rear seat and seat belt bolts. Then remove arm rest screws and pull the panel off. It takes time but not too hard...
<sk>
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
