2007 Tahoe Hybrid
I saw a show last night on HGTV called "2006 Dream Cars".  They touched on it a little bit.
http://www.hgtv.com/hgtv/spcl_prsntn/artic...6166_04,00.html
They also talked of a Ford pickup that ran on gas, hydrogen and E85.
Pretty cool. :cheers:
Getting closer to my 420 hp supercharged Silverado SS, running on E85 with DOD and hybrid technology to run all my appliances at the campsite!!! :cool:
:P
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
