Thermostatic Air Cleaner Valve
For some reason, I started looking at how the "thermostatic" valve in the air cleaner housing on my truck works. I think I was just trying to see how air flow worked when I put in a new filter. When cold, the valve is shut, then is supposed to open when the engine warms up and allow cool intake air a large path to the filter.
After running the engine and getting it to normal temp, the valve stays closed. It is the electronic kind (no vacuum lines). I thought that I would just replace it cheaply and forget about it. The valve/sensor is discountinued and the entire air cleaner base with the sensor is discoutinued from GM. I could not find any on line, either.
So, is there a way to test if the sensor works? It really restricts airflow, and I am hoping that it opens as advertised driving down the road, but when I stop and check it, it is closed. I have Banks headers with the stovepipe to the valve if that makes any difference.
If it is malfunctioning, any sources for a replacement? I am going to look in the salvage yard, but no promises of the electronic sensor working on a used one.
Thanks, guys.
  • 3 weeks later...
I recomend changing it out for an aftermarket air cleaner, Mine went out some time ago. I spent months looking for a replacement only to find out that GM has discontinued making that part. a K&N air cleaner will be cheaper and help your MPG's , good luck
that thermostatic air cleaner housing is just there for quicker warm ups of induction system, its an EZ enuf fix to remove the butterfly and seal off the hot air induction port with a plastic cap and some tape and let it ride..
its a disadvantage to power and fuel economy to leave it pulling intake air off the exhaust manifold
Thanks for the replies. I would replace with an aftermarket or seal it up, but both options will fail me for the emissions testing. They pull off the tube and inspect the butterfly valve. That's the big problem.
take the guts out of it, put it back together when it needs inspection, pass inspection and remove the guts for another year.
Might just work. And it will be for two years between inspections up here!
Thanks.
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
