Light chime wiring question
Installed an aftermarket keyless entry system, works great, except that it leaves on the parking lights after unlocking for one minute, which causes the door chime to sound when I get into my truck.
Best way to shut it up while the lights are still on? I have both +12V and grnd that are only on with the parking light.
One thing that occured to me was to just ground the wire to the drivers side speaker (I've heard this is the only one that produces the chime) while the parking lights are on.
I'd prefer to just trick it into thinking the lights aren't on when its just being activated by my keyless module, so what do I need to grnd/give power to in order to accomplish this?
Thanks for reading,
Tom
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
