Exhaust Rattle - Flex Pipe
msm20032003
I have a 2003 Silverado Regular Cab 4.3 V-6. I've been researching the common exhaust rattle/vibration that can be caused by a number of sources. I had the Catalytic converter replaced and it did not help. The dealer said the O2 sensors were okay. I replaced the muffler too, no help. I have read some things about some flex pipe that can be installed in the exhaust. Is there a TSB on this issure? I would like to bring it to the attention of my dealer. Thanks for the help.
Document ID# 1843079
2003 Chevrolet Chevy C Silverado - 2WD
Subject: Exhaust Moan/Vibration Noise (Install Exhaust System Flex Pipe Kit) #02-06-05-003E - (06/21/2006)
Models: 1999-2006 Chevrolet Silverado 1500 Series Extended Cab or Regular Cab/Long Box Pickups (New Style)
1999-2006 GMC Sierra 1500 Series Extended Cab or Regular Cab/Long Box Pickups (New Style)
with 4.3L Engine (VINs W, X-- RPOs L35, LU3) and Automatic Transmission (RPO M30)
This bulletin is being revised to add the 2006 Model year. Please discard Corporate Bulletin Number 02-06-05-003D (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on a moan or vibration noise at low vehicle speeds between 900-1200 RPM under load.
Cause
Exhaust system resonance that is transmitted through the powertrain mounts into the body may cause this condition.
Correction
An exhaust system flex pipe kit is available to correct this condition. If diagnosis leads to this condition, install the applicable exhaust system flex pipe kit listed below using the following procedure. Refer to the Parts Information for kit applications and usage.
Important: This fix and the kit part numbers are specific to vehicle frame type. A Level 3 frame was introduced interim 2000 model year (approximately January 2000). With a Level 3 frame, the transmission crossmember was moved forward of its previous location. Pre-Level 3 frames will require the installation of additional components to correct the condition.
1999-2000 4WD Models Built Prior to 1/20/00 and All 2000-2006 2WD and 4WD Models Built After 1/00
These models only require the installation of a flex coupling. The flex coupling has adapter sleeves for the installation of U-bolt clamps. This procedure uses the U-bolt clamps, but the preferred installation method is to weld the flex coupler to the exhaust pipe.
Raise the vehicle.
Locate the first available straight section of pipe rearward of the mid-joint flange and forward of the muffler assembly.
Measure approximately 228 mm (9 in) on the straight pipe and mark.
Using a suitable cutting tool, cut out the marked section of the pipe and remove.
Remove any burrs, if necessary, before installing the flex coupler pipe.
Install the flex coupling (1). Expand the sleeves of the flex coupler, if necessary, to properly fit over each pipe end. The centerline of the installed flex coupling should run parallel to the straight section of pipe (no bends in the coupling) for optimum performance.
Install the U-bolt clamps (2) on each sleeve end of the flex coupling.
Tighten
Tighten the U-bolt clamps to 30 N·m (22 lb ft).
Lower the vehicle.
1999-2000 2WD Models Built Prior to 1/00
These models will require the installation of a flex coupler, two Y-pipe support brace rods w/integral U-bolt clamp assemblies on the LH and RH sides of the transmission rear mount and new transmission mount studs and nuts. The Y-pipe support braces are used in combination with the flex coupler to reduce exhaust moan.
Install the flex coupler using steps 1-7 of the above procedure.
Support the transmission with a suitable adjustable jack stand.
Remove the two bolts and nuts from the transmission rear mount.
Position the transmission rear mount and install two new studs to the mount.
Install the new studs supplied with the kit to the transmission mount.
Loosely position the Y-pipe support braces w/integral U-bolt clamps (LH and RH) to the underside of the transmission rear mount and the crossover pipe as shown. The top ends of the braces attach to the underside of the transmission rear mount. The bottom ends of the braces attach to the crossover pipe using the integral U-bolt clamps. The braces support the LH leg of the Y-pipe where it crosses over the vehicle to meet the Y-pipe collector.
Install the two nuts to the transmission rear mount and the two nuts to the U-bolt clamps.
Tighten
• Tighten the new transmission mount nuts to 25 N·m (18 lb ft).
• Tighten the two U-bolt clamps to 30 N·m (22 lb ft).
Lower the vehicle.
Parts Information
Part Number
Description
Usage
15076982
Exhaust System Parts Package
15076990
• 1999-2000 4WD Models Built Prior to 1/20/00
• All 2000-2006 2WD and 4WD Models Built After 1/00
• Kit P/N 15076982 includes a flex coupler, two support brace rods w/integral U-bolt pipe clamps, two U-bolt pipe clamps (for use with flex coupler) and two new transmission mount studs w/fasteners.
• Kit P/N 15076990 includes a flex coupler and two U-bolt pipe clamps.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
*L3505
Exhaust Flex Pipe - Install
0.4 hr
Add:
To install transmission support brace rods (vehicles built prior to 1/00)
0.3 hr
*This is a unique labor operation number for use only with this bulletin. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
My 04 1500 4.3 had this vibration also, and after the second trip to the dealer I mentioned this TSB they installed the flex coupling and it cured the problem.
Thanks, I am going to look around today to make sure it's not a heat shield or the O2 sensors again, and if it is not I will mention it to my dealer. Where are all the O2 sensors at on a regular cab silverado?
The dealer found the problem. It is TSB 01485. The timing chain tensioner is causing it. They gave me an estimate of $891.00 to fix it. A guy was in with his 2006 with the same problem on the same day and he said his 2003,2005,&2006 models did it. I would think if GM found a fix they would use the new setup but maybe I am missing something. Do you have any more information on this TSB since all I could get is a summary.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 374 Guests (See full list)
