Speaker Removal
Hey guys, Im brand new to the forum and need some help on getting one of my speakers out. I have a extended cab 3 door truck and have replaced the two front doors, and extended cab door. My problem is i can't get the speaker behind the drivers seat out. I can't figure out how to get that panel off. Anyone have any pictures or anything showing how to get them off? Thanks so much. oh the truck is a 99 sierra extended cab new body style.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
