Sub stalling - What the...?
Okay, she's an '02 Z71 Sub with a 5.3 Flex fuel... Fuel guage is not indicating correctly, however, with plenty of fuel she stalls for no particular reason while driving. There is no Check Eng light and neither Onstar nor the dealer read any codes. She stalls at all speeds and driving conditions, but mainly while on the freeway... fine if it's just me, but not a good feeling when it's my wife and kids!
The dealer said the fuel sending unit is bad giving my fuel level indication problems.
They also said that I have to replace the entire fuel pump module to fix it. Drop the tank... etc. estimated around $800 for that!
They tested the fuel pressure and said it was sufficient, but she was running when I took her in...
They also suggested the crank (or cam?) position sensor... but wouldn't that give a code?
Also... if the fuel is low, there are times it won't start and I have to add about 5 gals of gas just to get her to start...
Well, I hope that's everything... any ideas or suggestions would be great. I may look into software for my laptop (i.e. EFILive) and scan it while I'm driving and hopefully as I stall... get the readings real-time... we'll see.
Thanks all for your time! :rolleyes:
Yah the funky gas guage is a very common problem mine messes up when its totally full but as soon as you get on the road for a few miles it works good it is a very common problem I think i remember on the "ask the GM tech" page someone clarified that you dont have to replace the whole assembly, contrary to what his dealer told him im not 100% sure but i do think i remember that id try a search since you are still getting good pressure
yeah, sorry... fuel filter's been replaced already.
Glad to know, if I don't have to, I don't have to replace the whole assy... thanks for your time!
Doug
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 966 Guests (See full list)
