hypertech power progrsmmer
garyhmb
how do you all have yours set up. how did u set up the settings on it to get the most out of your power programmer. by the way its for a 2002 v8 silverado 2wd stock.
I just used mine to firm up the shifting and calibrate the speedo to the tire size. The performance improvement isn't worth having the buy premium for me.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
