A/C Compressor Installation
Today i finish installing a new a/c compressor on my 2000 GMC Yukon. Tomorrow i am going to take it to the mechanic so he can do the vacuum and add the freon. Let see how this one works since the other two compressors i had in the past did not work properly because they were re-manufacture compressors, I am hoping not to have any problems with this one. I decided to do the installation myself since it get expensive paying a mechanic to remove parts, I hope they don't change that much to do the vacuum and to refill the freon. Rick
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
