Help, 4x4 not engaging
I have a 99 GMC Yukon 5.3l with an automatic transfer case. A couple of weeks ago I had the seals on the front wheels that go into the diff. changed, and since then the 4x4 no longer engages. Could the replacement of theses leaking seals cause my problem?
Did the mechanic remember to plug back in all the connectors he took out? =). Do the LED indicators on your switch do anything funny? These switches are known for failure, could be coincidence.
The only thing I could think of is that it has to be locked in 4WD during the procedure(or the diff falls apart and you gotta open it up), so maybe they screwed it up then.
I don't mean to hijack the thread... But I heard with pushbuttons systems from 4HI to 4LOW, and VV, the truck has to be in Neutral. Can anyone confirm this? Also, will it allow you to change between the two when in drive, or does it have a neutral safety switch(if that is the case)?
Thanks,
Mike
Thanks,
Mike
Yes, to go from 4Hi (or 2Hi) to 4Lo, you have to be in neutral.
Thanks,
Mike
This is correct. The truck must be in neutral to shift into 4-LO. I worked at chevy dealer last summer.. had a guy bring in a gorgeous 2500HD D/A because he couldn't be bothered to read his manual when it wouldn't shift into 4-LO. Oh well, didn't mind cruising around in it for a few minutes!
Does it require you to be in nuetral before it will even function(planetary gearset, correct?), or can I mechanically desacrate the system by hitting the button(in which case I will put a new set of buttons in with shields)? Also, how much reduction is offered in 4LO?
Mike
Mike
If you try to shift into 4-LO without the trans in neutral the lights will just blink at you and be like :cheers:.
4-LO gives a 2.72:1 reduction.
4-Lo + First gear + 3.73 rear = 2.72*3.06*3.73 = 31.05:1 overall reduction :P.
Just imagine what that does at the wheels when the engine is cranking out its peak torque at the flywheel! If you want to find out stick it in 4-lo and floor that sucker!.. but be sure your head is against the headrest first..
And I got the 350 In there(In 2Hi can one spin the tires with an empty bed?) :cheers:
I am hesitant to screw around with the engine because its got 80K on it and is working flawlessly.
BTW, I should have it registered and in my driveway by friday, I am so excited :P
Thanks,
Mike
Thanks,
Mike
As long as you don't do what my buddy did. He put the pedal to the floor in snow with the steering completly turned to the right, then shifted it in reverse at 2500rpm. Bye bye tranny!!
  • 8 months later...
Hi, i know this post is old but did you ever deicde what the deal was with the seals and the 4x4 not engaging?
i recently did this and have the same problem and im wondering if you have to be locked in to make sure the diff dosent fall apart.
Thanks
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
