serious wiring issue
bander02
The running lights went out on my trailer but not the 2002 Yukon XL. I worked back from the Yukon rear bumper towards the fuse box with a circuit check light with clip to ground. I assumed the trailer wire split off the Yukon tailight wire but eventually found that it has a seperate wire and fuse for the running lights. I replaced the fuse and the trailer lights worked. In the process of untaping and probing with the cicuit light I must have shorted something. The Yukon dash lights don't work, it won't crank and for a short while the fan would come on and go off. Tried again this morning and it acted like it was going to crank for a second and then nothing. The only light on the dash that comes on is the check engine light. Please tell me I didn't fry the computer. I unhooked the battery to let it sit while at work today and try again this afternoon. Any ideas or suggestions would be appreciated.
Problem solved. I unplugged the battery all day and when I hooked it back up it tried to start so I jumped it off and it started right up. Charged the battery overnight and all is well. One thing I did not mention above was that the A/C fan was going on and off when I had the switch to On and was looking at the dashboard lights or lack of them. Had a flashback to Christine. I guess having the headlights on for the 20 minutes that I was troubleshooting did the battery in. This was a wierd situation but I am happy it turned out to be cheap to fix. The thought of the computer possibly being fried scared me pretty bad. Maybe someone else can learn from my experience, I certainly did.
Thanks.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
