any common problems on 02's
I think the biggest problems with the '02s are the great financing and the rebates!!!   Oh wait,  that's not a problem it's a good thing!!!  LOL!!!
I haven't heard of anything major...  I think they are a much better truck than the '99s were when they were first intruduced.  And with just a few common problems with those trucks, I think GM did a great job introducing their first new truck in about 10 years...
Get used to people saying "Nice truck"!! I have had my truck to the dealer twice since I bought it. Once for a rear door courtesy lamp that was out the day I bought it (didn't notice it before I left the dealer). And once for a clunk that turned out to be my aftermarket running boards. The dealer adjusted them for no charge - they were installed by an aftermarket shop.
The only other problem I have is the look on people's faces when I pass them on the interstate while towing my boat! LOL
Bob G.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
