Passenger Window Inop
glafemina
I have 99 silverado 1500 4x4 ext cab new body style. Using the master window switch I can make the pass window go down but not up. I have to reach over and use the pass window switch to make the window go up. I swapped in a known good master window
switch, and still the same problem occurs. Im assuming broken wire somewhere...
Your best bet would be a terminal with a bad connection. It goes through 2 connectors. They are behind both kick panels. Take them apart see if the female terminals are spread apart. It should be the light blue wire in position A 10.
Thanks I will check out those 2 locations. Do those 2 connectors have the wires for the power rear view mirrors go through them also?
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,130 Guests (See full list)
