6disc in dash swap 06
Ironballs
Just got an 06 sierra work truck,.. basic basic with only an am/fm radio. I want stock looking and cheap. I found a cheap 6 disc in=dash unit from an 06 hummer (part number 15261537). Will this just swap in, enter the securiety code that came with the radio, and them be on my way?
that would be great if thats the case...
no, is the unit you bought a bose piece im betting it is. look to see if it says bose on it. if it does forget it. if not you can put it in but it will not work untill you take it in to your dealer and have it reset and even then they may not be able to do anything.These new databus radios are strange. they are vin set to the vehicle
I got the item. Seller says it is bose. Radio does not say bose anywhere, but does have a silver face, and seller says his speaker covers all say bose.
I hooked it up no problem. Had to cut a bit so the holes line up...
Pulled the batt, then the radio, then hooked it up, then the radio.
System worked great in accessory mode. Sounded great, fm and cd tested.
Then started the car and the stereo locked immediately. Display says lock. Seller gave me a 3 digit code, including a zero, but unit has no zero.
Dealer told me to come in, after 2-3 days to clear it (not right away, as if i tried to enter the code and did it wrong, then dealer cant access it either). I call BS, but will go there in a few days and hope he can clear it/make it work again
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
