I ate a bump stop...
I ate up a front control arm bump stop at the dunes last weekend. They are only $20 at the dealership ($13 something on-line) so no big deal. I soaked the bolts for a few days with blaster and last night they came right off.
Anyone know of a better aftermarket bump stop? I can find urethane aftermarket stops, in all sorts of pretty colors, that are about the right size, but the stops I took off the truck are two stage. The OE stops have a large rubber bumper that fits into a pocket in the lower control arm when it's compressed and then there is a second bumper that acts as the dead stop for control arm movement. Both of these bumpers are attached to a single plate that bolts on to the bump stop location. I will probably just order the OE stops and be done with it, but I wanted to check with you guys to see if there was a better option out there.
Thanks,
Steve
I have a set of Timbrens on the rear axle. They came with the truck (bought used). I didn't realize they made them for the front. They are expensive, but they look like they would work wonders!
Steve
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
