dead battery or charging system?
ben28881
About a month ago, I replaced the battery and alternator(rebuilt) in my 98 sierra 5.7. Not a problem until two days ago, when it simply wouldn't start. Sounded like a dead battery, but it is brand new. Once boosted, the truck will run with no problem until i turn it off and try to start it again. Then same thing, dead.
Please help
Ben
If the alternator wasn't charging, it wouldn't run very long after just a jump start unless you fully charged the battery. Even brand new batteries can go bad. We've replaced 'em in new cars on the lot with only 2 miles on 'em.
thank you then i will take the battery in to be tested. I guess that those delco batteries live up to their reputation. Thank you for the help.
Take your alternator too...find out WHICH of them is bad. It could also be that you simply had a battery connection come loose.
Your battery cables need to be tightened. I installed a new battery in my truck this summer. I tightened the cables until they felt really tight. Two days later the truck want start. I checked the cables and found that they needed to be tightened some more. I tightened them a total of three times before they stayed tight. I kept thinking that I was going to strip the terminals. Check them daily for a few days after a battery install.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 281 Guests (See full list)
