Ticking sound Piston Slap?? HELP!!!
A few weeks ago I noticed my truck started making a ticking sound that sounds like an exhaust leak. First think I did was change my oil and when that didnt cure it I put in lucas oil and when that didnt help I replaced the exhaust manifold gaskets but that did not fix the problem either. Then I took it to a gm dealer and after 2 days of diagnosis they tell me its piston slap. Now I know the 5.3L engines problem with the undersized pistons and all but to me the piston slap always sounded like marbles in the engine and not like a ticking sound you would get from an exhaust leak or bad lifter.
Also I should mention that the sound can hardly be heard from on top of the engine. Instead the best place it can be heard is under the engine when I stick my head right behind the driver side wheel. But its loud enough that I hear it echoing off the cars parked on the side of the road when I drive down the street. The ticking cant really be heard at idle but instead hear best just above idle &from 750 to about 1300 RPMS
so I have (2) questions
1- can this really be piston slap making a ticking sound?
2- if its not piston slap what can it be? The kicker here is it cant really be heard from on top of the engine.
this is 2001 Silverado 5.3 with 71K on it.
Can anyone please help? Im out of ideas
if it didn't sound that way for 71k then prolly not, if you just bought it then it prolly is. mine sounds like a disiel when i pull up to a atm or something, my LS1 did to
My Yukon with 5.3 2WD HAD piston slap, I run 5/30 Mobil Synthetic and it went away. Purrs like a kitten now and with 104,000 miles on the clock
Piston slap usually appears pretty early in the life of the engine and will quiet down after a few minutes of running.
There was a TSB a few years ago about an 'O ring' near the oil pump that could be bad. It would a clicking sound, I believe from the lifters.
Might check it out. Sorry, I do not have the exact TSB.
terry
Check to see if it the fuel rails on the top of the motor my 5.3 makes a lot of ticking when started and will stop after awile of running mine got lounder after i put an air intake and a flowmaster on it but i whent to a couple deelers and listned to a couple other trucks and i noticed that they made the ticking to BUT the newer trucks have an insalator over the feul rails
    250.3k
    chfkief
    chfkief
  • Who's Online   0 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
