map sensor
kuhnsy
my truck has recently been acting up pretty badly its' cutting out really bad and the exhaust smells horrible when it does so i hooked my programmer up 2 the truck n got the code and it was a map sensor code so i was wondering if u guys could gimme a lil guidance on this problem
a MAP code can set when it's running horribly because manifold vacuum is low, so this may be just a symptom, and not a MAP problem at all. On the other hand, you need a little diagnosis to be sure.
Can you read MAP values with your programmer?
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
