Looking to lift my 2500 HD
I'm looking to lift my 01 Hd 2500 4x4 about 6 inches or so, who out there make a decent lift?
I've leaning toward Fabtek, they seem to have the most ground clearance under the front diff.
What tire size are you running with your lift???
Your opions would help.
Thanks Mike
I have a Pro-Comp and I am very happy with it. I am running 355/65/18 NTG on mine, I had to do some minor "tweaking" to get the tires to fit. They look great and the tweaking is not noticable at all.
Thanks Mike
Just so you know...Fabtec is a spindle lift. They don't recommend wheels wider than 8" and you can not use wheels with greater than a 4-5/8" backspacing without spacers due to rubbing issues. Fabtec does however provide an integrated skid plate under the front differential.
As seen in my sig. I also have a ProComp lift. This lift drops the upper and lower control arms rather than increasing the length of the spindle. The ProComp is a whole lot more involved to put on due to more cutting, some welding, and such. And no skid plate under front differential.
Both lifts are great and will serve you well, just understand there are some differences.
Thanks Mike
The Fabtech kit allows the use of stock wheels which have a wider than 4 5/8"(5"BS) however, at the expense of wider front tracking compared to the other spindle lifts. You can use wider than 8" wheels with the Fabtech kit as well. I think you are confusing the Fabtech kit with someone else's. Both Full Drop(Pro Comp) and Spindle lifts have their advantages. You just have to decide which advantages are the most important to you. Just do a little research, as the subject of "Which is the best lift kit" has been thoroughly beaten to death and then some.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
