Part numbers needed or a diagram
spacehog
My 2005 Sierra got broken into... they cut the two black wires leading off the cellular antenna and the cables leading off of the XM antenna in an attempt to steal it.
Due to insurance reasons I would rather fix this myself... but I can't find a parts diagram that has the parts numbers for the antennas and the wires, and where they terminate. Anyone have clues?
The main thing I want to determine is if I want to tackle this myself. Removing the headliner/trim wouldn't be bad, but my concern is I'll have to remove part of the dash to get new harnesses in. Perhaps I should just splice?
Okay, I have some more information.
There are two wires leading off the OnStar antenna, which are both cut. So I need a P/N for the antenna. The antenna wires that go into the harness are both okay, but the sunroof cable (durr) was cut on the harness. I believe the easiest way would be to just splice in the sunroof cable rather than reroute the whole harness that has both OnStar coaxals in it, since those are okay and are likely hard to get to since it's buried in the OnStar module.
The XM wire is also cut, on the a-pillar. I can't find a connector anywhere to know how far this cable goes without a connector, does it go all the way to the deck? How hard is it to replace it?
This sucks :driving:
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
