2006 Bose Premium System Q's
abricko
I'm a bit confused...
I have replaced my factory HU but I chose to keep the stock Bose Premium Speaker System.
I used the Metra GMRC-01 harness and all seems to be working.
Two issues I've noticed though are the system seems to now have a constant hiss (audible when AC is off) and I've noticed that the volume control range is limited.
For Example: My HU has a range of 0 - 32 and If i put it past 12 I'll go deaf. And there's not much volume difference between 1 - 4. It seems to be either too quiet / no volume or starting to get pretty loud quickly
Am I missing something in this setup? Is the GMRC-01 causing the issues?
the gmah24b works way better it cost alittle more but its woth it . i have sold both and the peripheral piece works way better if you would like to buy one let me know. email me at [email protected]
How so does it work way better? I may want to get one if i install that one then i will not be able to fade front to back and i will lose the factory chimes?
you will have better volume and the hiss will go away. the chime is annoying. and fron to rear fade is useless. ide sacrifice chime (which they do sell an add on chime module, but most people do not want it) and fade for better sq any day
Sounds to me like the radio speaker level outputs are being fed into the bose amps low level input.
Couldn't you just use the rca outputs on the new radio, chop the plug ends off the other end and and connect the rca wires to the amps input wires?
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 429 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
