Can you get an F44 package on a Z71 K1500?
Hello,
Does anyone know if it's possible to order a K1500 w/both the F44 (HD) option, and the Z71 option? Or is it a one or the other thing?
Also, does anyone know for sure what "HD" options are included in the Z71 option? I had the dealer look up my VIN, (on my Z71) it does not have the F44 package, it also does not have the F44/HD 5 leaf springs; -it has the standard K1500 4 leaf springs. I don't think it showed wether the Z71 uses the same Torsion (sp) bars as the F44, does anyone know? It did list the "HD" tranny cooler, tow hitch, same Bilstien HD shocks, and a few other things. . . I should have written it down.
Hmm. . . does anyone know of a site online that will allow you to plug in your VIN and verify what options were installed in your truck?
Thanks,
-Justin
  • 3 weeks later...
Sorry for the delay to reply to your question but I just saw your post.
Yes,You could get both the "F44" and "Z71" packages on the 1/2-ton ext.cab trucks.
I had two trucks that I special ordered equipped this way,A '94 and a '97,Both ext.cab short-bed Z71's.
The Z71 package consisted of Bilstein shocks,Skid Plates,Different jounce bumpers and "Z71" Decals,thats it.
The F44 package consisted of the 9 1/2" 14-bolt semi-floating rear-end,bigger 11.15 x 2.75" rear brakes (over the std. 10 x 2.5") and an addtional leaf in the spring pack (5 instead of 4,as you mentioned) and most importantly it increased the GVWR from 6200lbs. up to 6600lbs.
The F44 package has nothing to do with the HD tranny cooler or hitch,and did not include the Bilstein shocks,those were part of the Z71 pkg.
The F44 package was standard on 1/2-ton ext.cab long bed trucks and 1/2-ton ext.cab trucks equipped with the 6.5 diesel engine.
If you PM me or post your VIN I can send you a build sheet with all the options on your truck.I work at a dealer and have access to it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
