hp help?
HammyJr
Hey guys;
I have a '98 Sierra 4x4, 5.7, and I was wondering where to start looking for more performance. I already did the exhaust. It is dual now, with a pair of Flowmaster mufflers. Should I look at programmers, or a cam, or is there an intake upgrade that can be done? You guys sound experienced, so I will shut-up and listen.
I can't seem to find alot using the search, maybe I'm not asking for the right things.
The truck has 3.23's, and at the moment I'm thinking of about $1000. More or less, I was curious as to where to start, best bang for the buck, sort of thing?
Hammy
Hammy
are you sure it has 3:23's ? if so , definitely lower your gears to 3:73 or 4:10
yea, if you have 3.23's, a gear swap is in need :) For power its simple, getting a tune works great. Also intake and exhaust kits are cheap and easy. But switching from 3.32's to 3.73's or 4.10's wouldnt be like night and day.
switching from 3:23 to 3:73 or 4:10 would be like night and day in all driving conditions other than top speed
Yep. Im not sure how much a gear swap costs. You could check out a junk yard for a Chevy that got front ended or T-boned or something and get the axle out of it. Just make sure it will bolt up :cheers::)
Plus if you get a tuned PCM or a performance chip, it would be an easy fix for the speedo.
I think I was wrong about the 3.23 gears. I think they are 3.73. Obviously they would be the same front and rear diff's, or there would be some carnage in the transfercase, LOL! :puke:
I'm thinking about going withe the PCM tune, but Sam, you mentioned an intake swap, and I've heard that the 5.7 intake is very restrictive, but I can't seem to find any for the 5.7, that aren't carb conversions. Do the parts from the 5.3, fit my iron headed 5.7, or does anyone have any sources for this? My intake appears to have a slight oil seepage from the intake manifold, so swapping the cam and intake might be ideal at the moment. I had my exhaust done from the cats back, it's 2 1/4", with Flowmaster mufflers. the cats and the head pipes are stock items.
Thanks Guys;
Hammy
Well cold air intakes are controversial. Some people swear by them, others hate them because they dont filter as good as a regular paper filter. Some people claim their K&N messed up some sensors from the oil the filter uses. I currently have a replacement filter thats K&N, the previous owner must ahve put it in. Its not a cone filter, its a regular rectangular filter replaceing the stock filter. So I decided to keep it, and bought the K&N cleaning kit. It hasnt messed up any seonsors. Some people probobly over oil theirs which probobly causes sensors to malfunction.
As for the PCM, I orderd mine from wait4me performance, its the best bang for the buck. But theres a few companys that make custom tuned PCM's, like Westers and pcmforless. wait4me is only $158.10 and you keep your old computer. I think other companys have you ship them your old PCM once you get your new one in the mail, and you get a core charge back. I got 10-15 hp with 87-89 octane tune, better shifts, no top speed governor, and it shifts at 5800rpms instead of 5500-5600. Im pretty satisfied with it, especially for 158 bucks. Their website is www.wait4meperformance.com (i think I spelled performance right, I always seem to spell it wrong)
Ill do a quick search on Summit for air intakes. Theres tons to choose from, some are oiled gauzze filters, some are dry paper cone filters ect.
Heres the link to summit for air intakes
http://store.summitracing.com/egnsearch.as...+115+4294840140
might have to do a copy and paste
Does anyone know if the 5.3 camshaft fits the 5.7? I had found some cams that I believe were Crane or Comp, I did a 5.7 application, their site said it was for a 5.7, but under the description of the cams it said replacement for 4.8/5.3 . I dunno, maybe I'll make some phone calls tomorrow and ask a tech.
I think you are right Sam. The best bang for the buck certainly seems like the pcm tune.
Any input helps, and thanks again for the info. :puke:
    Selfman
    Selfman
  • Who's Online   3 Members, 1 Anonymous, 451 Guests (See full list)
