Getting discouraged
The first amp I bought was known to be new/never installed. As I expected, I only got sound out of the right front speaker. I couldn't find a vehicle with the stock lux option that I could use to program the amp, so I bought another one used, supposed to have come from a Denali. Well, I got it in the mail, and it does the same thing as the other one. Sound only comes from the right front speaker.
So now I'm wondering, do I just have 2 amps that need programming? I thought a used amp wouldn't need programming.
...or do I have some other problem with my system?
And what's my next step? Buy a THIRD AMP? I don't know anybody who has a denali or escalade that I can use to try to program my amp.
To make matters worse, even if I solve the amp problem, the INR headunit I bought won't read CD's. I suspect it won't read the nav disc I have coming in the mail either. I tried opening it up and cleaning the little 'eye' to no avail. So I may have a useless $350 headunit as well.
ugggh.
I'm open for suggestions.
Thanks, guys.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
