Headers
Clavin78
I was looking for cams for my 03 4.3L and came up with these from comp cams http://www.compperformancegroupstores.com/...ory_Code=56-CAM . Now here is the question, I would like to get a tune first and then wait and get the headers later. But which cams would you recommend for street performace? I was thinking about the Chevy 4.3 90° w/ balance shaft Magnum 270HR Cam & Kit but I wanted to know what you guys thought and maybe any other cams you guys had in mind.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
