Anything new with NAV DISC 5.0 / 15906573?
endo
Just wondering if anyone has anything positive to report about the new 5.0 navigation disc, i.e., any UI/street naming/feature improvements to the NAV OS. I'm only concerned with software updates here....I don't really care about having the most up-to-date maps...my 3.0 disc seems to work reasonably well. Thanks!
  • 2 months later...
Bump to top - I'd like t know too.
I've updated to the new disc, and I haven't noticed any software changes...
Thanks. What's the date on the map data on that disc? There's been a lot of highway construction around here in the last couple years (not that I need to know my way around my own town, but I gotta admit - some of those new highways have exits in places you wouldn't expect)
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 499 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
