spark plugs
Hey guys thought this was kinda funny. i put nitrous on the truck at about 57,000 miles and now about 60 figured that i would change the plugs cuz of the bottle i was sapose to have better plugs anyway. So i talked to zex and the got me the correct plugs for the truck wow the stock plugs didnt look too bad not alot of carbon but the plugs had an interesting pinkish area and a green area around the electrode... realy cool looking but werid i assum this is the nitrous if i can take a pic i will and post it what do you all think
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
