Ive got a 2004 with the tan interior and some of the paint is starting to come off. Does anyone know if places like autozone carry VHT in the factory color? If so what color am i asking for?
Find a Auto Paint Specialty store and they will offer a factory match in a spray. I would suggest that you find a store that sells SEMs paint. This is the best I know of but it is more expensive than VHT.
They can also pull your interior paint code and make sure you get the correct color. Some of them can even custom mix interior colors and either add it to an aresol can or you can buy a small aresol sprayer such as Prevail.
I know i could do that, but why. I could just order the color on the internet for alot cheaper. I wanted to know it local auto parts stores carry or would able to order the right color like you can order on the internet. And i was wondering what the tan color was called.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
