Changing tire size 2500
I just got a new 06 GMC 2500 4x4 this week-end and want to change the tires from the stock 245s to 265s. A friend of mine ghanged his Chevy 2500 to the same and went to a Chevy dealer to have them reset the computer for the larger tires. Quess what, they told him that your not able to adjust it for anything larger than stock size. Is this true or just a brush off. I had it done to a then new 98 Z71 , it had 245s I wore them out then got 265s and the dealer I bought the truck from changed the computer for me. Has anyone else run into this kind of thing before. Thanks
I don't think you need to worry about the computer. I changed out the 245's on my 02 2500 Suburban to 265's and had no problem with the speedo. You should be OK and I think the dealer is giving you a line. When I changed my tires my dealer told me not to worry about it as there was not that signifacant of a size change to make a difference.
The dealer is not supposed to adjust speedo for large tires than stock. Google miata tire calculator and it will calculate how far your speedo will be off.
I went 265 to 285 and it was off about 4%
I'd try another dealer or buy a programmer.
If you went from 245s to 265s your speedo is off.
Well, I never noticed a difference with mine. Maybe there wasn't that much of a change.
There is a difference of about 3% or 3mph. The dealer will recalibrate also; mine wanted $64, I said no thanks, that's half way to a jesse tune.
On my 2000 K1500, the stock tire size is 245 and the "optional" size was 265. I upgraded to the 265's and asked the dealer about the reprogramming, and said no problem. Although the 265's aren't "Stock" they were an option, and should be okay to have the dealer update you. If you have them do it, don't forget, it's not just for the spedometer, but a separate ABS reprogram is needed too. He didn't know the cost off the top of his head, but said about $50.
BTW, I love my Michelin LTX M/S tires!
Thanks for the replies I see what another dealer says. I`m curious about this wait4me thing what is it and where do you get one, and what does it do? Also what is the cost?????
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
