Who are your local canidates?
Tucson_02Silverado
Moderators this maybe too close to the fence and I apologize if it violates forum rules...if so please delete this thread
THIS IS NOT FOR INDIVIDUAL CANIDATE "SOAP BOX" JUNKIES
GENERIC ONLY>>>NO NAMES>>>NO PARTIES>>>NO ACTUAL ADVERTISMENTS
All elections seem to be dirty...but this year really seems bad.
Based upon the advertisements, the canidate doesn't describe what they believe in and what they will do....but are very descriptive of their opponents.
The same seems to be true of the advertisements for propositions...the Yes/No groups respectively describe how the opposing side is bad, but never explain why their side is good
