1996 blower motor resistor location?
n1ghtfl1ght
Hello I have a 1996 GMC Sierra 4x4 Ext Cab 5.7... I have called around to many dealers and checked everywhere online but am unable to find any good help. My problem is that in installing a new blower motor resistor I cannot find it anywhere. What i need is a very specific lead to where it is because I have gotton many different anwsers. Also if possible a picture of this area would be nice and procedures to complete installation Thank you for all your help.
well i resolved the problem myself...They say you can reach the resistor through the glove box but that is impossible. so you have to loosen the two big bolts on each side of the dash near the bottom by the door then loosen the two nuts on the steering column than when those are out you can tilt the dash forward enough to see the resistor on top of the blower motor housing just barely to the left of the glove box in the far back against the firewall. well its all easy from there just two screws and its out for replacment. my resistor was black a sure sign it was bad. also a easy way to spot it is the big four prong plug. well that fixed everything so hope this helps.
:seeya:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
