Factory dimple or dent on diff cover?
Went under the truck to check for loose bolts/leaks, etc. after having the differential on my '07 1500 Classic rebuilt (at 730 miles), and noticed that the diff cover has a dimple in it, about 3/16 in diameter. The paint on the cover appears undisturbed, but I'm thinking a)the tech who did my ring and pinion dropped it and dented it, or b)it is a factory stamped dimple, probably there to hold a washer-shaped magnet in place on the inside of the cover.
Any ideas?
Thx!
You might have mentioned this earlier, but could you ell us again why you had to have your differential rebuilt this early on?
A quick check of his previous posts would reveal......
'07 Silverado Classic 1500 crew w/ 4.8 and 3.23 open rear. Also a great truck, but had a rear end whine around 40 mph since new. Took it to the dealer last week @ 700 miles. Tech verified the noise and replaced the ring and pinion and carrier bearings. According to his write-up on the repair order, the noise was still there. He contacted the GM service hotline, and they told him to reshim the pinion a bit tighter.
Picked up the truck Friday (they had the truck 4 days), and the noise is still there, at the same speed, but the volume of the whine is lessened by about 50%. It's not as annoying as before. I could live with it. Of course now, I'm listening for it, too
Question: has anyone had a similar experience? Will the whine get worse as time goes on and/or resuly in a rear failure in the future?
I have about 1200 miles on it now, and the whine hasn't worsened. It's still there, but I'm listening for it now.
The tech did a fine job- no leaks, no loose bolts (I checked 'em all- lugs, u-joint, diff cover). I'm going to wait a while before I decide to take it back for them to take another whack at completely eliminating the noise.
I guess it wouldn't bother me no much if the rear on my previous truck, an '04 Silverado 1500 EC w/ the 5.3 and 3.73 locker wasn't silent. It made no noise at any speed.
At least I know that the dimple in the diff cover is factory installed :seeya:
BTW: Does anyone have a squeaking driver's seat? Mine squeaks when pressure is put on the backrest, mainly on acceleration. I really hate to take it back to the dealer for this. maybe some felt tape where the frame and seat foam make contact?
Thanks for the replies.
My seat squeaked too after about 18000KM. Dealer took it apart and found a bolt slightly loose. Re-torqued and is now quite. Sure got irritating having to listen to that sqeak.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
