turn signal mirrors
acivitarese
Hey guys,
Thanks for reading this. I have a 2000 GMC Sierra p/u that has power mirrors on it right now. I want to install those cool looking mirrors with the leds in them. I found a set off a newer truck (used). Now I know they will fit onto the truck, however they probably will not flash when I hook them up to the stock wire harness. I would like to know the correct way to splice into my turn signals without damaging anything. Also the new mirrors have the power fold in function, will this work as well or does something else need to be replaced.
For the turn signal mirrors go to Muth Mirrors; http://www.kwmuth.com/ They will have directions on how you install their mirrors along with instructions on where to wire in the connections.
I don't believe they discuss the folding in part so I can not address that area.
Have a nice day.
Bill
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
