calipers rattling on rough road?
Valsport
I've been trouble shooting this for a while, wondering if anyone has the same issue.
Light rattling noise comming from all 4 calipers on bumps/washboard road. When I lightly apply the brakes it completely stops and the truck is silent. I have inspected pads/rotors for excessive wear, pads over 50% remaining. I cannot replicate the rattle manually with the wheel off.
Pad loose in caliper? Spring clip retainers?
Yes, had a buddy ride in bed and listen to both sides, then in passenger seat w/window down. You're right it is not a "loose caliper", the caliper itself it secure, all bolts torqued to spec, it has to be a caliper component. only reason i've made that deduction is because the rattle ceases when light pressure is applied to brake pedal.
Your solution is put a new set of pads on. I suggest Wagner Thermoquiet (you can't get a better pad for the money) with the lifetime replacement warranty from O'reilly Auto Parts.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 328 Guests (See full list)
