GMC engine dies
GMMan2000
Hi everyone!! i´m new to this forum and I have a 2000 GMC truck with a 323ci V8 engine i i have a rare problem with it.
It run great on the city but when i take it outside it starts to lower the RPM´s until it finally dies, i have to wait about 10-15 seconds before i can try to turn it on again, i already passed the scanner and no fault codes apeared, i changed the MAP sensor and it´s still the same, i checked the MAP sensor circuit and it´s ok too, can anyone tell me what is wrong with my truck?
Thank you..
Try cleaning the throttle body first, then go from there.  Checking fuel pressure wouldn't hurt.
I cleaned the throttle body and i took the Truck to the dealer for this problem and the checked the fuel presure and changed the fuel pump 2 times and it still has this problem.
Thank you
I cleaned the throttle body and changeg fuel pump and checked fuel pressure.
everything ok, but still has tehe problem, it only happeng on the highway. Could be a temperature or altitute related porblem?
I would change the fuel filter and see if that helps.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
