200,000 mile maintenance
200k
My 2002 Tahoe is about to turn 200K miles. Any suggestions on what should be checked out to assure continued flawless performance. I've done the recommended stuff pretty much at the specified intervals. Is there other areas that I should checked out?
Thanks
Thanks
Sounds like you should keep doin' what you've been doing. The timing chain probably needs changed or inspected soon.
Thanks
Wow 200k in 4 years, are you Highway Patrol? :D That is excellent. Whatever you are doing keep it up!
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
