question for Shaners
Shaners, I just ordered the husky mud guards for my HD. Did you install yours or did you have someone install them?.............if you did install them any tips for me?............thanks. The one thing I was looking at was how to undo the fasteners that secure the front fender flair moldings so I could install the front mud guards.........I hope their instructions are good............thanks again.........
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
