whole new system
i just got finished, check out the pics
front door: 6 1/2 Polk Audio db650
behind door: 4x6 Polk Audio db460
Amp: Kicker KX150
Sub: 12 inch Kicker CVR with Q-Logic box
Head Unit: Panasonic CQ-C7203U
Sweet man ..how dose it sound ?
Im looking at Getting a complete setup soon My only consern is that the head unit looks totally clean after instal.
I also vouch that Crutchfield is awsome to deal with and have very competitve prices.
good job :confused: i cant get my deck to fit flush tho... :crackup: how did u do it wit all the wires? I have the harness... other than that nice.. how do u like polk? ive got soundstream/alpine and its prettyawsome
Looks good man. I need to get some pics of my system up. I need to put carpet on the box first. I kept the stock radio, didnt wanna screw with the steering wheel adapter and some other adapter I'd have to buy. Still had to use one, but it was like 20 bucks, some s**t for the RCA's. What I love about mine is the sub is right behind the arm rest, so you look back and see the sub going crazy :lol: Also the Alpine is grey/black, the amp is too, so it blends in with the interior pretty well. The arm rest doesnt fold back anymore, a complete downside with my girlfriend in the truck :crackup::confused: but oh well, 6 feet of bed is enough.
Ill get pics up sometime soon, carpet or no carpet on the box.
Amp:  Kicker KX150
Excellent setup man.
I've got two of the 10" Comp V/R's in my truck now (had them under the seat of my ex-cab too). GREAT subs.
Thanks for the pics :confused:
nice im sure it must hit hard in the back of the truck with that one kicker CVR. I put 3 12 in back of the extened cab Sierra and it bangs hard. myabe i should put some picture up of my setup sometime.
I like the polks, great sound. The system sounds great, but there is a vibration on the passenger side by the seat belt somewhere, i have to fix that cause it's annoying.
And someone said something about getting a steering wheel adapter for a new head unit, I have no idea what your talking about, mine went in fine. Crutchfield gave me a harness and two mounting plates so it looks flush, and the wires in the back fit in fine, though i had to splice and connect a crapload of wires.
The only problem that I had putting it in is drilling a hole through the firewall to the motor, because you can't drill anywhere, because you can't be sure whats on the other side of the wall. Also at the very end, I tucked wires under my kick plate and was screwing it back on, and went through some wires (enough to piss ya off), but other than that, it was fun. :cool:
Sweet deal man...with the steering wheel adapter, that only applys to the NBS trucks with the Buttons on the wheel for the stereo and what not..i think its on 03 and up trucks.
Later
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
