01 Tahoe antenna cable base
Snap50
I need to replace the antenna base and attached cable.
Three bolts hold the base to the bodywork, but I need to know what interior parts (trim?) need to be removed to get at the inner cable connections.
Fixed Antenna Replacement
Removal Procedure
Remove the I/P trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gages and Console.
Remove the antenna mast.
Remove the outboard section of the cowl vent grille panel.
Remove the secondary air injection pump, if equipped. Refer to Secondary Air Injection (AIR) Pump Replacement in Engine Controls.
Remove the passenger side battery, if equipped. Refer to Battery Replacement - Auxiliary in Engine Electrical.
Remove the 3 bolts.
Remove the cable grommet from the body.
Disconnect the antenna cable from the extension cable.
Tie a long wire to the antenna cable.
From outside of the vehicle, pull the antenna base and cable assembly until the wire can be easily accessible. Ensure part of the wire is still in the vehicle
Remove the wire from the antenna cable.
Installation Procedure
From outside the vehicle, tie the wire to the new antenna cable and base assembly.
From inside the vehicle, pull on the long wire until the cable can be connected and grommet seated.
Install the cable grommet to the body.
Remove the wire and connect the antenna cable to the cable extension.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the 3 bolts.
Tighten
Tighten the bolts to 5 N·m (44 lb in).
Install the passenger side battery, if equipped. Refer to Battery Replacement - Auxiliary in Engine Electrical.
Install the secondary air injection pump, if equipped. Refer to Secondary Air Injection (AIR) Pump Replacement in Engine Controls.
Notice: Use tape on the tool surface so that you do not damage the paint on the antenna mast.
Install the antenna mast.
Tighten
Tighten the mast to 6 N·m (53 lb in).
Install the outboard section of the cowl vent grille panel.
Install the I/P trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gages and Console.
I replaced my antenna mount on my 01 silverado but never could get the grommet to fit into place. You cant get your hand on it due to the tight location. I guess I need to pull on the cable from the inside to snap the grommet in place ?
Removal Procedure
I assume the I/P trim pad is the black plastic trim panel around the face of the gages and radio. The word "pad" is throwing me.
Is that right?
Removal Procedure
Is that right?
I had to remove my dash board top in order to get to my antenna cable. The cable from the mount only sticks through the dash about 20 inches then connects to another cable that connects to the radio. It wasn't very hard to remove the dash. Had to remove the glovebox door to get some screws out, then removed the a/c grilles, stuck a screwdriver in the grilles to pop out the passenger dash grab bar...etc....my chilton manual helped out a lot.
Is that right?
No, the IP trim pad is the piece that is the whole top of the dash. The part with the defrost grilles in it. Yeah, they should be calling it a trim PANEL instead of a pad. There's certainly no padding.
Removing that trim panel is a job in itself!
  • 2 months later...
I dont know if anyone has successfully done this themselves on a Tahoe, but let me tell you I tried and it was MISERABLE!!! As I was pulling out the old cable, the wire I had attached to it slipped off, leaving me to fish the new antenna cable in with nothing to guide me.
For the life of me, I could not find the darn hole on the inside of the truck. I tried fishing in a longer piece of wire, a coat hanger, a fish-wire, you name it, I could not find it. I had the entire dash apart, along with the glove box, kick-panel, etc. and I still could not get to where this wire came in. There was so much stuff (seemingly HVAC related - maybe for the rear-seat air conditioning? 2001 Tahoe LT) in the way that I eventually put the thing back together after about 10 hours of trying to find this wire, and took it to the dealer to finish the job.
The dealer charged me $167.00 labor only to do it for me & that was money WELL spent. I would have gladly paid $400 for them to finish this because it seemed like an impossible job.
Total cost:
$167.00
10 hours of my time
Extreme frustration
10 bloody knuckles and scraped up arms from reaching into too-small places
My Reccomendation: This is one job that is not worth doing yourself. If you manage to not be an idiot like me and lose the leader wire to guide you back in, it may not be that bad. If you do lose the guide-wire though.... give up and dont waste your time!!
