Power Steering
dwerme
I experienced difficulty steering to the right in my 1999 Silverado 1500. I then replaced my power steering pump but the problem still exists. Any suggestions?
A pump doesn't fail in one direction ony, but I guess you found that out. Most likely a bad spool valve in your steering gear, but a pressure check would help to know what's going on.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,220 Guests (See full list)
