4WD Frontend Noise
jeepstud
Hello Guys-
2002 GMC Sierra SLE with Autotrac, 5.3L. Recently I have been having some new noises that sound to me like expensive noises. To aid troubleshooting I will try to provide as many details as possible.
The noise itself is somewhat of a rattling/ratcheting/tingy kinda noise. It does not sound or feel like something is binding then releasing (pop). It is not a growl (although mine does growl as well) Instead I guess it sound more like a baseball card in bicycle spokes, it is rythmic and seems to change frequency with speed. It is fairly loud, loud enough so that you could hear it if i rolled up next to you.
The noise does not occur in 2wd at all. The noise will occur in either Auto or in 4HI. I have not tried 4LO. As near as I can tell the 4WD appears to be working correctly. The auto kicks in smoothly and bites hard, as does the the 4HI. The noise only seems to occur as I coast down or maybe coast around a corner. As speed slows down it starting making that tinking noise. To me it sounds like it is coming from the drivers side (although that is where I am sitting).
I changed the front end oil and didnt see any chunks of metal and no change with the noise. I checked the 4WD actuator and moved in and out. I pushed on the fork the actuator moves and it felt free. I am not sure that I have ever heard CV joint noise although since the CV's spin all the time I would have expected to here the noise all the time (correct me if I am wrong). I did not see any burned out u joints on the front drive shaft and I could not get the CV's to make the noise on their own.
Is it possibly that some small binding when the truck is in 4WD versus 2WD is causing the CV to click? How can I check this (remove the CV and try and drive the truck?
Any help or suggestions of things to check would be appreciated.
Thanks
Trent
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
