NEW PRODUCT: 2007 SUV Predator Programmer!
Diablosport is about to release their new Predator programmer for the 2007 Corvette and SUVs.
U7194 Stock Vehicle Tunes:
93 Octane Performance Tune
91 Octane Performance Tune
87 Octane Performance Tune
U7194 Specific Features:
NOTE: Very early calibrations are not supported, update by GM dealer might be required for some.
COT time delay
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-7k
Rev Limit
WOT Spark 1k-1.8k / 2k-3.8k / 4k-7k
Fan adjustment, individual adjustment per temp dependent cell Speed limit (Truck/SUV only)
Read/Write time is approx 60 seconds
Clear codes supported
Live data and log supported
Initial release will only support ONE custom tune Dat viewer is supported.
All are standard DiabloSport Predator features!
How to verify that the vehicle is supported
The eighth (8th) position in the vehicle identification number (VIN) is the code that designates the engine type. The Predator will support the vehicle if the engine code is:
2006-2007 Car: 8th digit of the VIN= U or E
2007 Truck or SUV: 8th digit of the VIN= C, 3, 0, J, K, Y or 8
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are per tune. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
U7194 2007 Tahoe, Suburban, Yukon, Denali, Escalade, Avalanche and Corvette -
$399.99 with free overnight shipping in the 48 states.
Orders can be placed online or by giving us a call at 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
  • 7 months later...
Can you please explain:
"NOTE: Very early calibrations are not supported, update by GM dealer might be required for some."
a bit further?
Thanks.
I think it has to do with the engine code, and not all engines being supported:
COT time delay
Rev Limit
Have a good day!
two questions on this will it work on the silverados( their not mentioned} Also will it do anything to the TM having more power and torque is great but if TM wont let the trans put it to the wheels what good is it?
    MANGOAL
    MANGOAL
  • Who's Online   2 Members, 0 Anonymous, 410 Guests (See full list)
