Installing auto start on 94 gmc
mridolfo
Well as the title says I'm trying to install an auto start system on my wife's 94 4.3 c1500. The installing manual says i need to have a tachometer signal. But her truck doesn't have a tach. Does any one have a wiring diragram for her truck or know how to hook this thing up ?.
Thanks
Mike
  • 1 month later...
Thanks
Mike
Hi, Mike , I am new to this site, so I just now saw your post. For a tach signal tap into the WHITE wire at the distributor or coil. It can also be found at a single wire test connector taped to the harness near distributor. Hope I am not too late! John
Thanks
Mike
PS i have this info for any car or truck all you need to do is ask!
1988-94 GMC C/K Pickup Remote Start/Alarm info
Constant 12V+ Red Ignition Switch Harness
Starter Purple Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Brown Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel or left Dash Speaker
Door Unlock Black/White Reverse Polarity
Horn Wire Black (-) Steering Column
Now here is some you don't need to know but good to keep on hand:
1988-94 GMC C/K Pickup Cruise Information
Constant 12V+ Red Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Pink Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake White Brake Switch
Tach White Coil
VSS Wire Brown/White Light Blue 32 Pin Connector Position D-8 Passenger's Dash
Pulses Per Mile 2000 PPM
1988-94 GMC C/K Pickup Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer n/a
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 6" Rear Corners
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,659 Guests (See full list)
